SailNet Community - View Single Post - Full or fin keel?
post #644 of Old 03-08-2013
wolfenzee
wolfenzee's Avatar
Location: S/V Waltzing Matilda, Port Ludlow, WA (NW Puget Sound)
Re: Full or fin keel?
According to the US Sailing calculator http://www.sailingcourse.com/keelboat/design_winds.htm my AVS is 193.64
http://www.sailtrain.co.uk/stability..._stability.htm and http://www.radford-yacht.com/stablty1.html both explain the AVS
According to the RADFORD "Safety of Small Commercial Sailing Vessels Code of practice"(see table below and/or link), the 110 degree AVS that someone stated was typical of fin keels would not even be safe in Catagory 2 (up to 60 miles from a safe haven)
Historically the older style boats had a much higher AVS even though thier narrower beam. Typical sailboats produced from the early 70's on have LPS's (limit of positive stability = AVS) in the 100-120 degree range. "Designs typical of the 30's and 40's (e.g. many Alden designs) have LPS in the 160 degree range. from "http://dan.pfeiffer.net/boat/ratios.htm
The actual formula is: AVS = 110 + ( 400 / (SV-10) )
SV is the screening value and is calculated by:
SV = B2 / (R x T x V1/3)
Expanding SV in the first equation gives:
AVS = 110 + ( 400 / (B2 / (R x T x V1/3))-10) )
B = beam of the hull (no rub rail) in meters
R = ballast ratio
T = hull draft at B/8 from centerline in meters
V = displacement volume in cubed meters
It's not so much as a wide boat being more stable right side up, but upside down....I wide boat is not going to want to right as quickly as a narrow boat.
wolfenzee is offline
