SailNet Community - View Single Post - Magma marine grill recommendations
post #16 of Old 03-09-2013
Minnewaska
Re: Magma marine grill recommendations
I got my answer from the Force 10 website. They must be different from Magmas.
If you would like to use your BBQ with your existing propane system on board,
we or your local marine dealer have fittings and hoses available. There is now a
simple ‘quick-disconnect’ adapter which will fit any propane tank (see Diagram
4). It allows you to "T" right at the tank and still have the security of the solenoid
switch and manual shut-off valve for your stove down below. The Adapter, cat.
no. 8310, comes complete with a sealing cap nut. No tools are required for
installation. Remember to also order the special 6’ or 8’ hose, cat. no. 8316 or
8318.
CAUTION Force 10 BBQ’s must be hooked up to your propane system ahead of
your stove or heater regulator as the barbeque has its own regulator
(high/med/low) valve assembly. DO NOT DOUBLE REGULATE!
Jeanneau 54DS
Minnewaska is offline
