post #1809 of Old 03-09-2013
fallard
fallard's Avatar
Yes, it's the Cape May-Lewes, DE, ferry terminal just inside the Cape May Canal in Lower Township, NJ. Should you sail by the terminal, be aware that the ferries at the terminal keep their props turning when they are parked. You can see the turbulence on the water surface, but apparently they are churning up the bottom enough to create sand humps in the middle of the channel. We bumped a soft bottom there with our 6' draft--sure caught us by surprise!
You're turn to post, edguy3!
fallard is online now
