SailNet Community - View Single Post - Magma marine grill recommendations
post #20 of Old 03-09-2013 Thread Starter
TakeFive
TakeFive's Avatar
Re: Magma marine grill recommendations
I have some extra Char-Diamonds sitting around somewhere. I'll just have to go through 30 years worth of stuff in the basement to find them.
I hadn't realized that there are two models available. The one I posted before is less expensive, with no piezo lighter. There is also a costlier one with piezo starter and double walled construction at a certain area to keep the exterior cooler. I can do without the piezo starter - they always break anyway due to corrosion at the burner. But the double-walled construction would be both safer and probably more even heating.
So I'd appreciate knowing which one you guys have, so we can compare and contrast the benefits of each. Here's the other more expensive one:
Rick S., Swarthmore, PA
TakeFive is offline
