SailNet Community - View Single Post - Low buck projects- Let's see 'em!
post #526 of Old 03-09-2013
H2814D
H2814D's Avatar
Re: Low buck projects- Let's see 'em!
Originally Posted by katsailor View Post
How do you get in and out of the boat if the ac unit is blocking the hatchway?
It will only block the lower portion of the companionway. I am replacing the two lower companionway slats with this. The top of it will only be 20 inches above the step. In the event of a need for a quick escape, like a fire, it is easily stepped over. I also have a forward hatch that is large enough to exit in an emergency.
The unit will only be in place while docked in my slip. I need the shore power to run it anyway. Gets pretty warm on Lake Mead in the summer and I only anticipate using it while docked.
H2814D is offline
