SailNet Community - View Single Post - Dehumidifying the cabin while underway
post #2 of Old 03-10-2013
pdqaltair
pdqaltair's Avatar
Re: Dehumidifying the cabin while underway
Originally Posted by flandria View Post
In a seperate thread I asked and received good advice about insulating the boat since, especially in colder weather, we do get a lot of condensation. A related question here is how to best dehumidify the boat. Mind you, I do not mean plugging in a dehumidifier at the dock, but what, if anything, seems to work when underway or at anchor and things get cold and wet. We have used some of those moisture absorbing "buckets", which work on a small scale but they do add up $-wise and probably cannot handle a larger volume of air on a sustained basis. Keeping ventilation going is certainly part of the answer and I wonder if installing a dorade or two, or a solar-powered vent or something of that sort might be part of the solution.
Over to you guys out there!
Ventilation if it's warm enough.
Minimizing humidity from cooking, showers and heaters.
Also these can operate on 12V (they use a 110Vac to 12Vdc converter).
Sail Delmarva: Dehumidifier vs Desicant
They draw about as much as running lights and can remove 4-30 oz/day, depending on the temperature. About 20x faster than a CaCl2 bucket.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
