Back at you Cowboy
Sorry I haven't replied sooner, I am in Georgetown Bahamas right now and not always on the boat.
If you use the Volvo thermostat place a 1/8 inch spacer, in the shape of a gasket on top of the thermostat.
Believe it or not a weird thing that is not like a car is when you remove the thermostat in the A-4 it will still overheat. That is because it is a bypass type. What you have to do is pinch the bypass hose partly closed. Mess with it a little with regards as to how much to close off by engine temp. The bypass hose is the hose that runs to the side of the block with the T in it that comes from the raw water pump. With the hose not blocked most of the cooling water runs through the head and very little gos to the block. You are trying to balance these two.
I am going out to dinner now with some friends and will be back in the morning.
Fair Winds
Cap'n Dave
