SailNet Community - View Single Post - C&C 30 mast step
post #8 of Old 03-10-2013
msmith10
Junior member, rest old
msmith10's Avatar
Re: C&C 30 mast step
The problem isn't the block of wood you see under the aluminum fitting, although that may need to be replaced also. The block of wood sits above the bilge on crosswise frames which are wood, and may be covered in glass. It's those frames which can rot out and need to be repaired. You need to remove the block of wood you can see in the photo to assess the integrity of the true mast step-- the frames in the bilge which hold all that stuff up.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
