SailNet Community - View Single Post - Tips for dropping in an A-4?
post #4 of Old 03-11-2013
CalebD
Tartan 27' owner
CalebD's Avatar
Re: Tips for dropping in an A-4?
Originally Posted by jsaronson View Post
If you did not remove the tranny then you need to line up the engine with it. If you did not disturb the motor mounts you should be OK.
Good luck!
Much as this is good advice and would be helpful if you had a diesel with a separate transmission it has no bearing on an Atomic 4 which has an integrated transmission aft the engine block.
This poster is a good guy and is trying to be helpful so I'm not going to say more on this subject.
Everybody has one:
CalebD is offline
