SailNet Community - View Single Post - Tips for dropping in an A-4?
post #9 of Old 03-11-2013
Faster
Re: Tips for dropping in an A-4?
Originally Posted by taylor_sf View Post
I've seen the oil setup, and I want to research it more. I was trying to use the dipstick hole to remove cold oil from the old, seized engine (to make it lighter and less messy to remove) but I couldn't get it out. I can definitely see how the mod would help. On the other hand, I'm a bit afraid to go putting holes in my nice pretty (running!) engine. Gotta read that thread and give it a think.
t
For the oil drain all you do is replace the pan drain plug with a fitting you can attach a hose to.. the hose can come up to the top of the block and be stored/attached to something to keep it high. You can add a plug at that end if you like.
Faster is online now
