I bought a rebuilt Atomic 4 this weekend to replace the Atomic 4 that a PO filled with saltwater and abandoned inside the engine compartment. So, I have the old A-4 disconnected and ready to pull, and I plan to do so this evening.
I'm wondering if anyone has any tips or advice on hooking up the new engine. Things to look out for or be careful of? Any good tricks for lining the engine with the prop shaft? The mechanic I bought the engine from said it could take 10 minutes or all day, and I'd like to be on the 10 minute side of that.
Much as this is good advice and would be helpful if you had a diesel with a separate transmission it has no bearing on an Atomic 4 which has an integrated transmission aft the engine block.
This poster is a good guy and is trying to be helpful so I'm not going to say more on this subject.
Taylor,
Perhaps your best bet for Atomic 4 specific advice is over at the Moyer Marine forum: Moyer Marine Atomic 4 Community - Home of the Afourians - Powered by vBulletin
Very helpful group of people there who have done what you are intending to do and will freely give you good advice. That is not to say that you wont get good advice here but it is highly likely that most people here have diesel engines of one sort or another. Doing the engine alignment is the same whether diesel or gasoline powered though.
One of the first things you should do once you remove the old A4 is inspect the engine mounts carefully. Check for any rot or soft spots in any wood used to make the engine beds. The engine beds need to be firm and strong otherwise your engine is likely to go out of alignment.
If the engine beds are solid then it should be a straight swap. Alignment is done using precise shims that get inserted under the engine mounts. McMaster-Carr
Caleb, thanks for clearing that up. I was wondering how that would be possible. The shims are a good tip. I'll look for them at McMaster-Carr.
I asked on the Moyer Forum, too. -- Couldn't decide which location was best. : )
t
Edit: Additional note: I'm pretty sure the PO moved the engine mounts while he was working on the old engine. In the time that I've had the boat, the engine was never connected to the propshaft.
Especially for the one you're taking out, if you remove the alternator/generator, exhaust manifold and anything else that hangs off the side to create a smaller, lighter package to feed out of the compartment and out of your companionway that may save some dings and scratches.
You can do the same for the dropin if you find that a helpful measure. If you've got lots of room and plenty of grunt then maybe it's no big deal.
Like the idea of inspecting/cleaning up/replacing any mounts at this time. Also take the time to thoroughly clean the area underneath the engine and paint it before dropping in the new one.. get some oil soak pads and lay them under the engine, it will be easy to keep it all clean for some time.
Take this opportunity to make an oil pan suction line off the drain plug connection so you can pump the oil out from there rather than mess with a dipstick tube, and take a page from Porfin's book and clean and paint the 'new' engine before you drop it in. Nothing say's 'well looked after' like a clean engine and compartment.
I'm on the same page. : ) The old engine is in pieces. The new one is painted and fresh. She's a beaut! Can't wait to make the engine compartment pretty, too.
I'm thinking I'll see the state of the mounts once the old engine is out. I think I'll look in my Ericson 29 manual and Don Casey's Guide to Sailboat Maintenance to find out about his tips on engine alignment.
I've seen the oil setup, and I want to research it more. I was trying to use the dipstick hole to remove cold oil from the old, seized engine (to make it lighter and less messy to remove) but I couldn't get it out. I can definitely see how the mod would help. On the other hand, I'm a bit afraid to go putting holes in my nice pretty (running!) engine. Gotta read that thread and give it a think.
For the oil drain all you do is replace the pan drain plug with a fitting you can attach a hose to.. the hose can come up to the top of the block and be stored/attached to something to keep it high. You can add a plug at that end if you like.
You might think about the rebuilt engine's cylinders possibly rusting if you don't get the beast running soon. Would hate to see a rebuild lock up. Did the re-builder give you paper with any kind of warranty?
Good luck!
That's a really good point. I'm pretty anxious to get it all hooked up and going and take the boat out for a spin (might not even sail ), but it's good to keep in mind that I should have it running sooner than later. (It last ran Saturday. I hope to have it running again by Thursday.)
I just dropped it into the cabin, but the old engine mounts were shot. So I'm hoping to get new ones tomorrow and set it up.
And the mechanic said that he only gives a full warranty on the engines he installs himself (at a fee of 50% of the cost of the engine). However, he also said that if I had any trouble he would not charge me to come look at it and fix it (and that he had spare parts he could use).
I can understand you being anxious to get your "new" engine all set up and wanting to try it out. I think you need to take a deep breath though.
You will not be able to clean up the area under the oil pan once the new engine is in AND there is really no point putting a new engine in if the stringers/engine bed are not rock solid.
I am also curious about the warranty this mechanic is offering. Is he the one who rebuilt the engine?
If you have already run the engine (hopefully Rotella T 30w or 15W-40 oil in it) then you have splashed oil around the gearbox. If you are at all worried about the cylinders as Denise has suggested then simply squirting an ounce or two of Marvel Mystery Oil (rust inhibitor) into the spark plug holes is not a bad idea at all. Then turn the engine over briefly or use the hand crank to turn the flywheel a few turns to help spread the MMO around.
Swapping one A4 for another should be a straightforward proposition but do take the time to make sure you have done everything you need to before that engine goes back into what is usually a pretty tight engine compartment.
I'm still waiting to hear what kind of boat you have and what year?
And yes, the mechanic ran it for me before I purchased it. He was the one who rebuilt it.
The stringers seem solid. The compartment is pretty clean. The PO had the old engine out shortly before it filled with salt water. I'm going to wipe it down before moving the new engine to the engine compartment. I'm not going to rush things if I run into anything that isn't finished. But I've checked the exahust, and I'm looking around. Things look to be in relatively good shape.
I'm in full agreement with others who recommend attending to your engine spaces before you install the new motor.
"Pretty clean" is good; spotless is better. Think about it. You are never again going to have the relatively unfettered access to this area (unless you pull the motor again.) "Pretty clean" today means "getting grungy" not too long in the future. If you start from spotless, then grungy is much, much further down the road.
I did this a couple of years ago. Starting with the old engine in place I took lots of pictures for reference.
I should have replaced the exhaust at the same time! O-well! That is done now. I did clean and paint everything with the engine out. I added a fw heat exchanger so locating and installing that got consideration with the engine out of the way. My boat, an I-28, has a fg engine bed and was sound as were the mounts. I used a couple of pieces of angle iron to act as rails to slide the rebuilt into position. Blocking and jacks helped. I did it alone.
Alignment was a concern but once I had the rebuilt back on its undisturbed engine mounts I checked it with a "trick" used around here. Three bolts secure the shaft coupling to the transmission flange. I took three small pieces of paper and placed them against the transmission flange between the bolt holes. I rotated the shaft and waited for one of the scraps of paper (the surfaces were clean and dry) to fall out because of an alignment issue. I repeated this "test" several times and all three pieces were firmly held in place by the coupling. Satisfied that things were fairly close I tightened things up and have had no problems.
It also gives you the opportunity to reconfigure things for easier access - inaccessible fuel filters, rerouting wiring & hoses so they are neat and out of the way etc. etc.
When the boat was built all those were done to be fast & cheap in nearly all cases - serviceability was seldom considered.
Your time is now.
By the way, if you have to add some steel angle to reinforce your mounts & so forth, pay the $2 and use stainless so you don't end up with a bunch of rust in a few years. If you're as OCD as me, sand it smooth & polish it before installing it.
Moyer is your friend, things to do before you slide it in there:
Electronic ignition kit
Retrofit alternator with Moyer's beefier one, (Hey, VW canceled Motorola in frustration).
Fit the oil change kit to the pan fitting on the engine's port side
rig her with Moyer's electric fuel pump kit
Consider fitting new trick motor mounts that have fresh rubber to keep her quiet
Check the exhaust elbow, probably ought to be new
Buy some Marvel Mystery oil to add to the go juice and keep her valve guides happy
Any money left?,put the oil filter kit on...
Hire the engine guy that has the laser alignment kit to help slide her in
Enjoy the smooth quiet of an A4 loved and happy....
Oh and another thing, just about everyone around here adds the plastic coupling to the shaft which helps mitigate the alignment problem and protect the engine assemble in case of grounding, line wraps and the like.
All of the above! I am not familiar with the "plastic coupling" FDR can you steer me to an information source. I am getting ready to replace my cutlass bearing and will need a new shaft coupling. It is my plan to buy the split coupling from Moyer.
I believe the words you wanted to use are "well rounded" or "cuddly"
Related Threads
1.7M posts
173.9K members
Since 1990
