SailNet Community - View Single Post - Weatherfax audio file for testing
post #14 of Old 03-14-2013
RichH
RichH's Avatar
Re: Weatherfax audio file for testing
Originally Posted by tombesore View Post
As for that fuzzy signal, I am wondering if I had the greyscale option selected instead of b/w. The signal was strong and noise is minimal. The antenna is a 140' long Windom stretched between the ship's mast.
I'll give it a try again and hope for better results .... also using the tuning tweaks suggested earlier in this thread. Thanks for the suggestions.
Try aligning your antenna to straight vertical as much as possible ... horizontally polarized antennas are subject to pick up a lot of 'noise' from automotive type spark ignition engines and are highly insensitive to signal coming in at the 'ends' ... better to be 90 from the broadcast origin; vertical antennas seem at times to better dampen out such automotive induced background noise and are more omnidirectional.
RichH is offline
