SailNet Community - View Single Post - Mostly singlehanded...what lines should I run aft?
post #3 of Old 03-15-2013
jameswilson29
Senior Smart Aleck
jameswilson29's Avatar
Re: Mostly singlehanded...what lines should I run aft?
I agree, with the exception of the spinnaker halyard, so you can blow it if you broach, the mainsheet, jib sheets, foreguy, spin pole topping lift, twings, and spin sheets. Don't bother running other lines aft unless you are an invalid or like to buy gear. Otherwise, there is no need. You can walk the 10 feet up to the mast.
jameswilson29 is offline
