SailNet Community - View Single Post - c&c 99 hull survey question
post #5 of Old 03-15-2013 Thread Starter
brianc
Re: c&c 99 hull survey question
Thanks for the replies. I'm going to walk, there's just too much risk.
The boat in question was produced the same year as the C&C 121 that had so many problems, and while there isn't any hull cracking on this boat, the root cause seems like it could be the same, especially with the appearance of the new and large voids (there was actually a third void identified around the back-stay chain-plate which I forgot to mention earlier,) maybe 'progressive' as Faster mentioned, will eventually mean the whole hull...eek.
Assuming there was a real issue, if there was a fix implemented, does anyone know which hull numbers/years are the problems?
I can't find that information so unfortunately, that probably means I'll avoid all of them.
brianc is offline
