SailNet Community - View Single Post - Battery choice
Thread: Battery choice
post #5 of Old 03-16-2013
chef2sail
chef2sail's Avatar
Re: Battery choice
Originally Posted by jeffzee View Post
voyagerct: Thats exactly what i was thinking about the gel cel/agm's, I could buy two regular deep cycles for less then 1 fancy battery.
Its not that its a fancy battery,. If you had the right setups for charging and usage it would fit and be cost effecticve to get an AGM. Gel, but you dont so what you decided to get is an appropriate choice.
Also, If you had greater usage needs I would suggest two 6 volt golf carts as the thicker plates allow a much greater number of deep cycle charges thus greater life.
What you have decided is appropriate for your use, just be sure they are deep cycle batteries.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
