SailNet Community - View Single Post - Ipad as sailing instrument....
post #6 of Old 03-17-2013
NewportNewbie
NewportNewbie's Avatar
What u need are the transducers to get the depth and wind data. If you do that with nmea compatible instruments you can get them sent via wifi to an iPad. That will require something that sends that data via wifi. This currently will probably cost you as much as a entry level instrument sail pack. After you have that having the data sent to an iPad is doable. What you also have to worry about is powering the devices and since it's done via wifi having something create a wifi network like a computer. For a small boat that may be alot of power requirements. There may be other options but from my research this is what may be involved. Raymarine and I think simrad have an iPad app that allows you to see the nmea data on their network. You still have to get their instruments and build that network so it's not in addition to the instruments not instead of.
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
