Old 03-17-2013
hasuehounds hasuehounds is offline
hasuehounds is on a distinguished road
Re: I've become very concerned about the weather...
Best advise; go to bouy weather or a weather
Service and look for a five day forcast
Plan a short distance trip and work point to point.
Trying to plan long distances, for a beginner that
Has limited to no experience navigating in changing or
Bad weather will only discourage you and damage your boat.
Plan a trip of 30 miles to start then chart your course point to point.
When we started cruising full time we started in
NC to Bahamas. We took the ICW most of the way.
That first year we went one day all day then found an
Ancorage that night rested are and go on.
We averaged 12 hrs a day around 40-50 miles
That included delays such as bridges.
We made Florida in one month then waited
There for a weather window to the Bahamas.
Looking at such long range, your setting yourself up for
Problems,disappointment and failure.
Find a short range easy plan. Prepare using good weather tools
Plan 5 day weather, then when you have a good weather
Window go to the first goal set. Each day set a new goal.
Stop worrying about being cold wet and stalled.
Prepare. Find weather then move. You'll learn new skills. You'll gain confidence..
Good luck. Btw both if us took sailing courses
Before we left and we had navigation programs to
Use on our chart plotter.
Going to sea without education, the right tools and
Preperation with the goal of living in the cheap is an
Expensive and costly pipe dream!
If the weathers bad sit it out! If your ready then find
Weather and go.... If you get in trouble call the
Ciast guard!!!!
Being unprepared can set you up for real issues!!
The pacific is the hardest ocean to navigate, find harbors and
Deal with... Learn & plan better. Look short term and you'll succeed!!!
Fairwinds and following seas
