SailNet Community - View Single Post - How can this happen? Shroud Tension
post #10 of Old 03-18-2013
tommays
tommays's Avatar
Re: How can this happen? Shroud Tension
The most common time i have seen this is on Rod Rigging right after the mast was stepped as you cannot see how well the headed part of the rod is sitting in its mating part
The tballs are supposed to have a rubber plug inserted in the slot above the fitting which holds it in the correct place and I see them MISSSING ALL THE TIME
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
