The year is gone, and 2006 marked the year Giulietta was launched. What a year. What better way to remember than to show the various steps of her construction??
Here is my "homage" to all boats built in 2006. Enjoy!
Here is Giulietta's birth!!
The very beginning, laying the gel coat (brushed not sprayed) onto the mould.
Then, after the hull was made in Dyvinicell and Fiber glass/Kevlar/Epoxy sandwich, the main hull beams were made and glassed.
Bellow, Giulietta is inside Giulietta, really!!
The the deck removable wood structure was bulit and covered with dyvnicell stitched to the wood
(the wood was removed after the glass fiber was applied)
The photo bellow shows the Dyvinicell (I 'll call it PVC from now on), already shaped to my desires!!
Once the PVC was as I WANT, I gave orders to fiber glass the whole boat's deck.
After Galssing, the deck was painted and sanded 10 times!!!
till perfection with 2 part
epoxy.
The deck was then removed, and layed up side down next to the boat, and time came for me to decide
how I wanted it inside, where I wanted the bulkheads, and what type of furniture we wanted.
The water tanks were protected as they are moulded in the boat's hull, and the water balst tanks connected.
The furniture was first made with cheap wood based on my body's dimensions, the doors and
seats were made as per my body, too.
Everything was made for my confort.
The Heads and all interior is PVC also, either glassed or coverer with Cherry wood (I bought in the US by the way!!)
The keel was moulded in FG, then filled with XXXX lbs (its a sectret!!) of lead
The Yanmar and saildrive installed.
The heads painted with 2 part
All furniture finished
Then.... she came out of the mould (that was destroyed by the way!!)
The teak applied.
The gear installed
And finished
Then..... she saw day light!!!! The keel installed rudder is secret!!
And Into the water she went!!!!
The mast installed,
The nice things inside were connected and tested
ET VOILÁ!!!!!!!!!!!!!!!!!!!!!!!!
Here she is, GIULIETTA!!!
Wasn't that fast???
Thanks for watching!!
I edited bellow afterwards:
Please note that I didn't build it, I had it built by Delmar Conde Yard, in Aveiro Portugal, a yard with a vast experience and over 60 sailing vessels all hand built.
Delmar is also the Builder of PT INOVAÇÃO, now MIKE DAVIS, 5 times Portuguese Champ. and whose hull mould was used on my boat.
I just designed the deck and interiors, to fit in a racing hull!! That's all I did, and I spent countless days and hours admiring them work, I did
varnish a piece once, but that's all I did.
