SailNet Community - View Single Post - Perkins 4.108
Thread: Perkins 4.108
post #6 of Old 03-19-2013
PorFin
Seņor Member
PorFin's Avatar
Re: Perkins 4.108
James,
It occurred to me you may have been referring to the raw water pup and not the fresh water pump.
My comments and parts number are for the fresh water pump (i.e. the belt driven pump on the alternator side of the block.)
If you had the raw water pump in mind (i.e., the Jabsco or Sherwood, located right under the Bowman heat exchanger/header tank), then rebuild kits are in fact available.
All the best,
PF
________
'85 BYB Vagabond 39
PorFin is offline
