SailNet Community - View Single Post - Determining storm distance by wave freq. or ampl.
post #7 of Old 03-20-2013
casey1999
casey1999's Avatar
Re: Determining storm distance by wave freq. or ampl.
Originally Posted by geronimotwo View Post
wouldn't wind speed, and the change of wind speed have greater effects on frequency of the waves than the distance of the storm?
I did not completely read the article, and do not fully understand what I did read. But my understanding is wind speed, fetch, and time determine wave height. As your distance from the winds that generated the waves increase, the wave height decreases. Also, waves travel in the direction of the wind that generated them. You could be 500 miles from a storm, but a location 3,000 miles away may get larger waves if that is the direction the waves are moving. The frequency of the waves gets lower (longer wave length) as you move farther away from the storm. The acticle says somthing to the effect the lower frequency (longest wave length) waves travel faster and arrive first at a location, then the shorter wave length waves arrive.
Here is a good site to see how this all works:
Sailing Weather - Marine Weather Forecasts for Sailors and Adventurers - PassageWeather
Compare the maps that show wave height and direction to the maps that show wind speed and direction. Note these maps do not show wave frequency (wave length) but you can bring up bouy data that does give that information. For the same height wave, the wave with longest wave length (lowest frequency) has the more energy and will break with a higher height once it reaches shore. This can be seen in a tidal wave. At sea, a tidal wave may only be 6 inches high (and moving at 500 miles per hour), but its wave length is measured in miles, and when it hits land, it generates huge amounts of energy. Although a tidal wave is not generated by wind, the physics of the wave model are the same.
casey1999 is offline
