SailNet Community - View Single Post - Harness and Tether Recommendations?
post #38 of Old 03-21-2013
outbound
outbound's Avatar
Re: Harness and Tether Recommendations?
Jack lines at base of house inside the shrouds. Top of pulpits/safety lines 30" up from deck .Combining up and down safety lines and distant from jacklines more then the 3' of short arm of tender even with stretch of jackline. . If go over head and shoulders would be well above toe rail. Try to always go forward on windward side. If go over in front of shrouds use spin halyard to lift crew back on board. If go over behind shrouds climb back on through sugar scoop or use outboard hoist on starboard or topping lift/secondary main halyard on port side. Also carry a spare block and tackle as well as a Life Sling . Admiral only weighs 100lbs. so we both have thought about this drill. For her - fear is a wonderful thing. Figure I'll just bend down and pick her up. It's me that's the problem as usual.
Use nylon for jackline in cockpit.
s/v Hippocampus
Outbound 46
outbound is offline
