SailNet Community - View Single Post - EPIRB or PLB for coastal cruising
post #30 of Old 03-22-2013
jackdale
jackdale's Avatar
Re: EPIRB or PLB for coastal cruising
Originally Posted by jameswilson29 View Post
"...Small and mighty, the ResQLink+ is a full-powered, GPS-enabled rescue beacon designed for boaters, pilots and water-borne sportsmen...[emphasis mine]"
As is the quote from my post
The ResQLink+ is a buoyant PLB but is not intended for operation in water
Intended operational environments include on ground and above ground
including held in hand
Near the bottom of the specs.
The Aqualink is also COSPAS/SARSAT approved. The ResQLink+ is not. (They will still rescue you.)
jackdale is offline
