SailNet Community - View Single Post - Send packing the stuffing gland..
post #31 of Old 03-22-2013 Thread Starter
macwester26
Have a go and DIY .....
Re: Send packing the stuffing gland..
Originally Posted by fallard View Post
The only o-rings in my PSS shaft seal are on the rotor, which is fixed to the shaft. There isn't any maintenance that I feel is necessary here. You could check with PYI to get there opinion on routine maintenance.
I replaced my bellows when they were about 18 years old. They seemed stiff to me, but there weren't any drips, so it was purely precautionary. PYI advised me that this was the right approach. The newer bellows use a different material.
My dripless shaft seal has performed flawlessly for 22 years. I do not have the tube for water lubrication, which makes more sense on a power boat running longer and at higher revs. My seal gets lubricated by whatever water gets thru the cutless bearing.
I've wondered about a catastrophic failure but, should the seal or bellows blow out, it seems highly unlikely that enough water would flow past the cutless bearing to overwhelm a bilge pump. I'm fairly certain I could keep up with it using the manual backup bilge pump in my cockpit.
I have read the above with great intrest many thanks for the posting.
I guess there may well be something one could use as an emergency in the event of a failure. Like denzo tape or something... at least it will buy some time .
Comments welcome on what one could use.
Robert
macwester26 is offline
