SailNet Community - View Single Post - Alberg 30 - Yah or Nay!
post #18 of Old 03-23-2013 Thread Starter
KiwiSails
Re: Alberg 30 - Yah or Nay!
Scratchee - yes would really appreciate some input from the A30 Chris-N-Cate folk. Perhaps I can message them - not sure how this forum works but will check it out.
True, it normally holds that if the visible is poor then you would expect that the underlying hidden to have issues.
In this case expect assuming the survey assessment holds (from a year ago) then there are a few areas requiring review as noted from the survey....see extract for the review of the Deck...."The deck and coach roof were examined for deficiencies, as were the stanchions and lifelines. They were then percussion sounded for delamination as well as measured for excessive moisture with a Skipper TRAMEX moisture meter. Overall, the decks were sound with no signs of soft spots, major cracks, crazing or other irregularities noted, with the following exceptions; at the bow, the area adjacent to the port anchor line hawse hole measured inflated moisture values. Additional inflated moisture values were noted adjacent to the waste pump out, the port water fill, and fuel fill deck plates, and the entire aft deck. The cause of the high moisture is attributable to moisture intrusion from failed bedding. However, this phenomenon has occurred over a period of forty - eight years, with no apparent effects to the integrity of the overall structure. Accordingly, consideration should be given to re- bedding all through deck penetrations associated with these areas at a future maintenance period. Thereafter, it is suggested that deck rigidity is constantly monitored, with any indication of significant flexing within the deck, a sign of the need for repair. All stanchions and lifelines were sound."
As for the Hull the survey noted the following which did not concern me...."The bottom was closely examined for any deficiencies that might affect the seaworthiness of the vessel. It .was then percussion sounded for delamination, observed for blistering. Neither blistering nor delamination was observed. However, several areas were noted in which the undercoat of bottom paint was sloughing off. This typically an indication of a failure in the adhesion of paint layers, usually a result of too many layers. Ultimately, all layers will have to be removed to the barrier coat, and a fresh coat of bottom paint applied. The interior of the hull was then observed, where accessible, for structural deficiencies. Bulkheads and frames were examined for delamination and inspected for decay or detached bonding. All were found in good order."
Overall this was not bad in my view considering the boat is a few years older than me. Of course assumption here is that winter has been kind for the past 12 months while the boat has been stored.
KiwiSails is offline
