SailNet Community - View Single Post - Fiberglass buildup around rudder stuffing box
post #8 of Old 03-23-2013
svHyLyte
Old as Dirt!
svHyLyte's Avatar
Re: Fiberglass buildup around rudder stuffing box
The failure is the rudder stock stuffing box. The problem is that the former owner obviously didn't know what he/she was doing and apparently laid in additional glass below the shaft log, and in the process embedded the locking nut in the added material. What you need to do is use a dremel tool to carefully grind away the build-up and free the locking nut to the shaft log. Then, tighten the upper portion of the log until the dripping is all but gone and, holding it steady, tighten the locking nut against it from below. Problem solved. See image and attached snap of your situation below.
svHyLyte is offline
