SailNet Community - View Single Post - Send packing the stuffing gland..
post #41 of Old 03-23-2013
eherlihy
Learning the HARD way...
eherlihy's Avatar
Re: Send packing the stuffing gland..
I installed a PSS before the beginning of last season. If you are interested, you can read about it here: Contemplating a drive line overhaul
So far, I am happy with the installation. I have not had a drop of water infiltrate the hull since.
The "gotchas" are:
  • the set screws are meant to be used once. Many yard monkeys don't get this.
  • the "O" rings can be damaged by grease/oil. You can only lubricate them with dish soap, and you should ensure that there are no burrs on the shaft that could damage them during the install.
  • PSS should include a redundant collar (they don't), because of the potential for failure if the installer damages the set screws. If you go with a PSS, you should find and install a collar, as a backup.
eherlihy is offline
