SailNet Community - View Single Post - bottom
Thread: bottom
post #9 of Old 03-25-2013 Thread Starter
Arjen
Re: bottom
Thank you all, This really helps
When i sand down my bottom to an even surface, is it no problem if there will still be some of the old antifouling remaining and i paint the barriercoat over that ? or should i maybe only apply new barriercoat to those areas that are exposed and/or going to be repaired and not where the old antifauling is still firmly enough attached to the hull that a bit of paint scraping and some sanding will remove it ?
Arjen is offline
