SailNet Community - View Single Post - Mostly singlehanded...what lines should I run aft?
post #119 of Old 03-25-2013
outbound
outbound's Avatar
Re: Mostly singlehanded...what lines should I run aft?
Jon- Really appreciate the heads up. You're right have the Raymarine with the long arm. They offer two remotes. The bigger one was rechargerable and showed instruments but thought the smaller one made more sense hanging around your neck. Figured KISS. Guess will have batteries in a baggie in the cockpit pocket and foulie pockets. Can you turn the pilot off at the wheel console and then just use that after you turn it back on? Will the system accept input after the batteries in the remote go dead?
s/v Hippocampus
Outbound 46
outbound is offline
