SailNet Community - View Single Post - Mostly singlehanded...what lines should I run aft?
post #122 of Old 03-25-2013
outbound
outbound's Avatar
Re: Mostly singlehanded...what lines should I run aft?
thank again Jon. Boat comes in to Norfolk Va around may 15th. Then will sail direct to N.E. after rigging and brief shake down.Small crew so expect to be on autopilot the whole time. Will let you know. Expect ~3d for pasage which may not be enough time for batteries to fail. But then will be coastal and mostly singling so should know soon enough. Folks like you are a major reason I piss off the admiral and spend so much time reading posts. (GRIN) You're the best.
s/v Hippocampus
Outbound 46
outbound is offline
