SailNet Community - View Single Post - Mostly singlehanded...what lines should I run aft?
post #123 of Old 03-26-2013
macwester26
Have a go and DIY .....
Re: Mostly singlehanded...what lines should I run aft?
Originally Posted by NewportNewbie View Post
I am planning on doing some deck work and everyone says this is the time to run lines to the cockpit. What lines should I run aft? Right now the only lines aft are the main sheet, jib sheets, topping lift and travelers. I was planning on running the cunningham and boom vang back. Should I do main halyard? Spin Halyard? I am going to be using an Asym. Spinnaker I assume the topping lift isnt needed? Anyone have before and after pics?
Hi NewportMewbie.
We will also soon be running back everything to the cockpit area.
Mainsail up and Down.
The foresail genoa is on a furling and goes to the cockpit anyway.
I can't think of anything else I may need ....
This will be enough for me I am sure.
macwester26 is offline
