SailNet Community - View Single Post - C and C Mk2 portlights
post #2 of Old 03-27-2013
Faster
Re: C and C Mk2 portlights
You'll have to check the Lewmar catalogue and know your existing port dimensions, and probably have to pick the next size up. This might be a difficult job because IIRC the MKIIs cabin has a fair bit of curvature.. Opening ports will only tolerate so much before they won't seal properly and the lenses can be under stress when closed.
It would update the boat considerably, though! Another option might be to simply replace your lenses but put a small opening port into the lens itself if its big enough, that would provide at least some cross ventilation and mean less finishing work as well.
Good luck!
Faster is offline
