SailNet Community - View Single Post - quick bottom job!??!!-- !!
post #6 of Old 03-29-2013
macwester26
Have a go and DIY .....
Re: quick bottom job!??!!-- !!
You should be able to seal the area by sanding around the filled area and then applying a coat of the same resin used for filling.. applied with a rag / sponge / or thinly with a brush. SEALED...
The very same resin you seal holes with after you have drilled holes through either the hull or the deck.
Applies to G.R.P.
Having said that Marine plywood can be sealed using The West epoxy Resin.
macwester26 is offline
