SailNet Community - View Single Post - A couple wisely decides to head back in...
post #26 of Old 03-29-2013
RichH
RichH's Avatar
Re: A couple wisely decides to head back in...
Originally Posted by mr_f View Post
Why are their lifelines so loose? (This is an honest question. Rephrased: are my lifelines too tight?)
Structurally looser life lines (and jack lines) will be 'stronger' vs. impact and 'side forces' (load applied at ~90 to the long axis of the wire.
Mathematically, with a 'tight' cable or line if you apply a load perpendicularly, the resultant loads 'along' the cable or line begin to approach 'infinity' (dividing by the trigonmetric SINE of the angle .... dividing by 'near zero' winds up being a very LARGE number, or a VERY large applied stress); however the innate elasticity/stretch of the cable or line at max. stretch will relieve those angles (making those angles larger than 'zero' at the two attachment points of the cable or line).
Suffice it to say that your lifelines need to be well over ten times stronger than the max. impact load expected and applied at 90 to the long axis of the wire ... and then you always add a 'safety factor' on top of that.
Obviously you dont want 'sloppy loose' lifelines as that promotes a 'functional' failure.
Rx: dont make your life lines or jack lines 'bar tight'; a little 'slop' in the wire is 'useful' from a 'strength' viewpoint.
RichH is offline
