SailNet Community - View Single Post - Vectran sleeve for anchor rode?
post #6 of Old 03-29-2013
pdqaltair
pdqaltair's Avatar
Re: Vectran sleeve for anchor rode?
a. I think you will have some problems with the sleeve moving separately from the rode. Normally the sleeve and line have similar elasticity.
b. I think you will need some chain--at least 10 feet--to hold the shank down during setting. I have tried going without chain for small boats and it is a problem. Even more so with high-mod lines, which generally less dense than nylon (float).
Consider using some chain backed by high-mod and using a VERY long snubber (50 feet). Multihull sailors understand your point. With that sort of a performance boat, non-conventional solutions must be investigated. My last boat was an all-Kevlar cat and carrying much chain was out of the question.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
