SailNet Community - View Single Post - Acoustic Insulation for engine room?
post #25 of Old 03-30-2013
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Acoustic Insulation for engine room?
I've seen a commercial lead/foam sheet that has a fairly dense black "polyfoam" type of foam with a sheet of lead sandwiched to it and a foil backing on the lead side. How does the group think this might work if you first lined your engine compartment with sheet lead then attached the foam product with the lead side "in" - this way you'd have the foam creating the dead air space between two skins of sheet lead.
It would cost several $hundred but the theory seems to fit well with the comments in this thread.
SloopJonB is online now
