SailNet Community - View Single Post - Acoustic Insulation for engine room?
post #30 of Old 03-31-2013
Flybyknight
Re: Acoustic Insulation for engine room?
Flyby, Is that lead foil in the middle between TWO layers of foam? Can you make this up yourself in the engine room or does it have to be pre-manufactured sheet goods?
Sure if you have the lead foil and a good pressure sensitive adhesive that is compatible with the foam you use.
The really good high end foam is rubber.
Dick
Flybyknight is offline
