SailNet Community - View Single Post - wet keel
Thread: wet keel
post #2 of Old 04-01-2013
SchockT
SchockT's Avatar
Re: wet keel
I assume you have a fiberglass encapsulated lead keel?
I had that problem on my first boat. Water just kept seeping out of the holes I drilled in the bottom, so I couldn't even seal the holes. I went out and bought a cheap mini shop vac, taped the hose over the holes, and left the vacuum running overnight. When I came back to the boat there was no more water seeping out and it was dry. I repaired the holes, and never had another problem.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
