SailNet Community - View Single Post - Why doesn't my Perkins have any Zincs?
post #2 of Old 04-02-2013
swampcreek
swampcreek's Avatar
Re: Why doesn't my Perkins have any Zincs?
You probably have the same situation as me and my Yanmar...
I went through this last fall. I bought 2 pencil zincs because the manual stated that the 3GM30 had zincs that required maintenance. I bought 2 and went to the boat. I could not find the screw plugs that the manual said was there! I went back to the shop and they asked if I had a 3GM30 OR a 3GM30F? I said I had the 3GM30F. I was told that the fresh water cooled (IMO should be known as antifreeze cooled) Yanmars didn't need zincs due to the special metal used in the exchanger...So I researched because I'm nuts about boat things and I need to know! I found out that the material used for that heat exchanger was something called cupronickel which has a very high resistance to corrosion, many heat exchangers are simply copper and do require zinc protection. Here is a link on Cupronickle.
2000 Catalina 320
Previous:
1993 Macgregor 26S
1981 Hobie H16
19?? Sol Cat
19?? Penquin
Many, many power boats
Life should be an adventure, not a guided tour!
Not all of us in the herd are sheep.
swampcreek is offline
