SailNet Community - View Single Post - Adding Hydro Foil to Yamaha 8 HP 4 Stroke on 27 Catalina
post #13 of Old 04-02-2013
overbored
overbored's Avatar
Re: Adding Hydro Foil to Yamaha 8 HP 4 Stroke on 27 Catalina
not the only one with the issue. outboard powered sailboats have limitations on the conditions that it is safe to operate in. so far has the engine you have been a problem or is it that you are just worried about a problem that does not exist. if you find that going at top speed is drowning your motor then don't go that fast. problem solved.
"GOLD RUSH" PRINDLE 16
overbored is offline
