SailNet Community - View Single Post - Anchoring with changing tides and wind
post #26 of Old 04-03-2013
zeehag
snake charmer, cat herder
zeehag's Avatar
Re: Anchoring with changing tides and wind
when in doubt, ask someone who is already anchored where they set their hook and from which direction they set it and what they use , and you will learn fast.....
every anchoring i do is in tidal waters with clocking winds--every direction daily each. isnt hard to make it work. i do it with one genyooowhine bruce 30 kg anchor and using 150-160 ft on ground in 20ft of this changing situation and i have no problem.
isnt hard to learn, and do not forget to ask until you are secure with your method which will change for you until you have it set into your mind.
formosa 41, cruising tropics
zeehag is offline
