SailNet Community - View Single Post - Catalina 27 Keel stub and bolts
post #2 of Old 04-03-2013
Faster
Re: Catalina 27 Keel stub and bolts
This image:
http://www.blumhorst.com/catalina27/...m_catalina.gif
suggests running the glass 6" up the stub. Presumably the hull/stub transition is sufficiently strong from the beginning so this repair/change shouldn't change that structural requirement, there may not be a lot gained by glassing up onto the hull proper.
I'm a little surprised that Catalina recommends glassing around/across the keel/stub joint on the outside.. anyone done this? It's a relatively light layup that I'd think would be prone to cracking when this area inevitably flexes over time...
Faster is offline
