SailNet Community - View Single Post - Biogas Producing Holding Tank
post #5 of Old 04-05-2013
eherlihy
Learning the HARD way...
eherlihy's Avatar
Re: Biogas Producing Holding Tank
Most holding tanks are in the 20-30 gallon range, which equates to ~50 litres (26.7 gal to be more precise). However, just because a holding tank can hold 30 gallons, they usually are not more than 2/3 full. You want to cram it to full capacity, because of the danger of overfilling, or any leakage.
Didn't the story line of Waterworld have something along these lines, using pig waste... or was it Mad Max III?
I am unclear on the ratio of methane produced per volume of black water, per unit of time. You seem to be equating volume of black water with volume of gas, or implying that the ratio is 1:1. I don't think that you will get that much. Also, if it takes 3 months to achieve a complete processing of the material, then it isn't going to be practical (what do you do with the rest of your effluent for the 3 months). I would also think that the temperature and composition (ratio of solid to liquid, pH, affect of Cl, etc.) of the black water would have a direct affect on the efficiency of the production from the bacteria.
I am not trying to discourage you, as I believe the idea has merit. If you get it to work, and patent it, you'll be rich and famous! However, I doubt that it will be simple.
eherlihy is offline
