post #3857 of Old 04-07-2013
Sapwraia
Pilot (Dog) House / Deck Saloons etc - Vilm 115
The interesting thing about the CR 380DS is how difficult it is to get the aesthetics right on a hull of that size, even if the interior spaces work out ok.
I recall comments by Chuck Paine when he was doing his fast cruiser designs, saying the trick with raised-seating deck saloons is getting the visual bulk into the back half of the hull and integrating well with the cockpit/coaming profile - very hard to do under 48 ft he said - probably why Southerly put so much work into the design of curved deck mouldings for their smaller yachts.
This new design Vilm 115 caught my eye - deigned by Judel/Vrolijk - never heard of the yard and don't think this has been built yet, but they have a lot of models listed (no website in english). I've always liked JV's designs and they've done a reasonable job with a dog-house on a yacht of this size - a nice design for gentle weekend cruising when you're 70+
I like the big and well protected cockpit (sun and wind) - esp if you're going to have a soft dodger up full-time; also a huge galley and heads (like the HR372) but the compromise is a saloon pushed well forward with mast post through middle of the table (not ideal and a throw back to the IOR pin-tails when tiny mains and huge genoas meant rigs were set well aft). Fwd cabin also tight; aft cabin looks large but must have quite a bit of cockpit moulding intruding into that space.
Performance looks like it will be ok from the stats and hull drawings
LOA 11.09 m
LWL 9.76m
Beam 3.54 m
Draft 1.60 m
Displ 7,200 kg
Ballast 2,550 kg
Sail area 71 mē
A bit light on ballast though @ 35% (vs XC 38 @ 43% and HR372 @ 39%) which coupled with shoal draft and dog house windage won't make this an upwind performer
They also have plans for same hull without dog-house (I see these designs being called pilot houses in Europe, but agree with U.S. terminology here - if you can't steer from it then its only shelter so a dog-house !)
Presumably a drop-down transom platform but not shown. Would be a bit nervous of a rudder that looks like it's at full keel draft ! I happily go to shallow waters but only if a spade rudder is at least a foot shorter than the keel !
Having gone to the trouble of plans from JV it's a shame its not being built by a better known yard - saw mention of EUR200k in the water. Moody would probably do ok producing the 2 versions of this yacht.
cheers
Sapwraia is offline
