SailNet Community - View Single Post - That can't be good..... right?
post #7 of Old 04-07-2013
jrd22
Courtney the Dancer
jrd22's Avatar
Re: That can't be good..... right?
Med- I'd drill a small hole in the bottom of the keel directly under the hinge to see if more water comes out. If it does then there must be a void in that area. You might be able to figure it out by tapping with a small hammer to determine the size and then drill holes and fill with epoxy, at least that's what I've done on rudders that had water in them. Good luck, wet day to be working under the boat.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
