SailNet Community - View Single Post - Busted Navpod
Thread: Busted Navpod
post #5 of Old 04-07-2013
hellosailor
Re: Busted Navpod
R-
Probably best to call or email Ocean Engineering to make sure what plastic they used in your particular model. 949-588-1470.
If it is a clean break, crazy glue might be fine, but most plastics will distort when they break they way and crazy glue will not fill the resulting mismatch. Could be a little Marinetex (precolored epoxy putty) or for a clean result, maybe putting a little support inside the broken part and then gluing back down over it (the same way you'd put a sheetrock patch on a hole) might be more durable, and waterproof, and neater.
hellosailor is offline
