SailNet Community - View Single Post - Roberton Autopilot - Can I still use the linear drive if the autopilot does not work?
post #2 of Old 04-07-2013
knuterikt
Re: Roberton Autopilot - Can I still use the linear drive if the autopilot does not w
Probably, these drives usually have four cables.
One pair is to run the drive the unit - the direction is controlled by reversing the polarity.
This is done by the course computer.
The other pair controll the clutch.
Two things to check
-Max amp for to drive (computer and drive)
-How many amps does the clutch use
knuterikt is offline
