SailNet Community - View Single Post - Proper way to tap into 12VDC wire?
post #25 of Old 04-08-2013
L124C
L124C's Avatar
Re: Proper way to tap into 12VDC wire?
Originally Posted by hellosailor View Post
L, are you trying to add all your taps up front at the source? Or along the length of a longer run, at different points? "Additions" are pretty much always a compromise, unless you make home runs to the power distribution panel. Lots of options depending on what you are doing and what you'll accept as a compromise. (Cost, convenience, labor, got to finish today but the store is closed...)
I'm not adding anything, just trying to eliminate stuff like this from PO's (see picture). Definitely not doing home runs for each light (does anyone do that?).
Just diagnosed a problem and fixed it with a patch.
Short in lighting circuit affects radio?
I'm tired of patching and want to come up with a plan to do it right. Thats how I ended up at this thread.
L124C is offline
