SailNet Community - View Single Post - How to glass
Thread: How to glass
post #1 of Old 04-09-2013 Thread Starter
davidpm
davidpm's Avatar
How to glass
This picture is of a piece of construction plywood made into the top piece of the centerboard trunk that also is a support for the mast of a dinghy.
It is for my rainbow dinghy if you remember my prior post.
I have some fiberglass cloth and some epoxy so I figure I might as well cover it.
Covering a flat surface with cloth is easy enough.
This piece has so many corners and curves, any tips on how to cover it smoothly to cut down on the sanding.
davidpm is offline
