SailNet Community - View Single Post - Go-To boat cleaner
post #1 of Old 04-09-2013 Thread Starter
Minnewaska
Go-To boat cleaner
What's everyone's go-to boat cleaner?
Why do you use it? Most effective? Environmentally sensitive? All-purpose?
I've been using Tuf-Enuf for cleaning the gelcoat and canvas. It also works incredibly well on teak too, if you spray it on full strength and scrub lightly with a scotch pad.
I hate the bucket and brush approach to cleaning. I just put it in an industrial spray bottle and walk around with the hose and brush. I rinse, spray a bit, brush and rinse off. Easy.
I've slowly been ditching all other products, like dedicated teak cleaners, de-greasers, etc.
It leaves a slightly waxy feel, which I've always wondered about. No idea if that is good or bad. It is not good on Eisenglass, as it leaves a film. This is what the MSDS says is in it. Anyone know what this stuff does?
Alkycylarysulfonates, alcohol, and inorganic acid neutralizing and chelating agents: 2- Butoxyethanol, CAS # 111-76-2- TLV Units 25ppm
There is a downside. If I don't keep the topsides well rinsed, which is nearly impossible to do, it will take the wax/sealer off.
What do you use?
Jeanneau 54DS
Minnewaska is offline
